Interesting read:
http://www.ascc.gov.au/NR/rdonlyres/097A66...eport_jacks.pdf
Regarding deaths while working on the car when the jacks fails. Example from one of the death incident: guy jacked up his land rover and put SPRINGS under the range rover to support it up and removed the jack so the range rover was only held up by springs while he was working on it... guess what happens next.
OMG ... one nit-wit had the car on ramps, in gear only, and removed the tailshaft ... guess what happened next :P
Some people just shouldn't go near cars.
Told ya I had a big back yard.
Pic from a while ago. You can see where the pool is going in. Got Council approval and the SA Water permit! :)
The tap for the garden hose is where the house extension finishes, and still got 200m2 open space :P
ooooooo 28-135
how have you found it as just an every day lens ?
is the picture quality superior to the standard 18-55 kit lens ?
It's an Ultrasonic Lens with an Image Stabilizer..........it kills the 18-55 lens!
A great intermediate lens.
LOL thats not a big back yard, (my dam is bigger than that)
this is mine
a comfy 100 achres (lots of room for a private trst track and drag strip if it wasnt so hilly (no flat quarter mile strip :( )
Hmm, 8.5km from the CBD? :)
Altough I would kill for a large block for some dirt biking ... I love being so close to the city.
Edited by RubyRS4
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
