Straight to the point, looked (by accident) the keys in the boot of the GTR... Boot release doesnt work, so.. How to get them out, havta catch the damn bus to work cos my daily drive keys are on there also :banana:... Raa be able to 'break in' to it?
Also was lucky the boot didnt catch on fire as the rear right hand light has burnt out the left globe and wiring, hence the reason i was in the boot, put my keys down for a second and with the frustration of the rear light almost catching alight i shut the boot with them in it... What to do? Any ideas.. Stupid problem i know.
cronic a little information you may have missed
hey wat causes missfire?
coilpacks, plugs...
i have changed plugs and gapped them, and used another set of OEM coilpacks and still missfiring.
any ideas on wat else i can change? coilpack loom??
coilpacks, plugs...
Timing could be way out? Did you plug everything in properly?
yeh timing was done when the water pump was changed 3km's ago lol...
im thinking the OEM coilpacks are not coping again...
s1 or s2
if its a s1 rb25det check the ignitor could be playing funny buggers just a suggestion.
Well the RAA dude this morning got the keys out, dont know how as i wasnt there, apparently they have a 'special way' of opening a boot lol
Anyways all good, thanks for the help people.
Now to buy a new boot lock, anyone know where i can buy one from? Thinking nisswreck or similar..
Whootage
Cleaned my car just before, the piece of shit actually tubs up alright (if you don't look at the back) :)
Also swapped the innards of the dizzy over on the poobucket daily and it drove roughly a million times better. Still got a very occaisional misfire, but it's been run down to 5/8ths of fk all petty a few times and the fuel filter has probably picked up some crap, so I've got a new one to put in when I cbf.
All in all a good days work ;)
Edited by AndrewJZX100
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
