how much? will they fit in the single DIN position under my stereo???
are they out of a r33?
They'd fit in a din sized slot easily, the main thing you have to find out is if the cables are there for them to plug in - integrated GTR gauges get their readings from the ECU, not an independant sensor. My GTR's centre gauges have two plastic plugs that clip in to the back, not sure if those plugs are there on 33's and 34's or non GTR's
-D
need $100ono to go towards new tyres on the front of my car as they are forked.
yes its single din , i had em in my skyline just to fill the gap between my air con and fold out screen
yes they are from an R33
as Dohmar said above^^^^
do u have the plugs for them???
i'm not gonr hook them up 2 my ecu, i just need the plug to have the pos/neg/illumination wires, thats all ill hook up
by the looks of it, in a GTR it must of been where the climate control was coz the right side has no corner so if i fit it under my stereo there will be a slight gap
nah dont have any plugs , just the unit its self
here is my stealth ute shes a monster now with the black sunnies and truck pipes, wonder how long till the cops pull me over bout it. :)
keep a look out for this at glandambo 4x4 event if anyone here goes to it you might see me there this year. im gunna jump the table top and land in the mudpit, hopefully land on all fours.
on another note is it illegal to have your cam gear cover off as i want to get some purdy red cam gears.
have u got a tray on the back of that? can guarantee with no tray or protection over the rear wheels you'll get looked at, but otherwise id say it'll be stealthy :)
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
