rofl,
Poll Results
Thanks for voting, here are the results so far:
Have the tougher laws introduced in 2005 reduced hoon driving in SA?
Yes
29% (43 votes)
No
70% (105 votes)
Total votes
Total of 148 votes
This is taken from the poll on hoon driving..
Pathetic creatures who "need to" do burnouts and all that childish idotic behaviour. Who says they "need to" do this? How about getting a life, some real responsible friends and a good hobby? Look at other countries. Does Europe have this problem? Not really. Let's ask them why. There is plenty of opportunities here to let off steam, like football, etc. etc. "Test their vehicles"? What for? Read the instructions: a car is a means of transport, that's all. Not a goofy toy to show off your infieriority complex and other mental disturbances to people who aren't really interested!!!
Seriously some people have no idea. Yet they feel the need to voice an opion about a subject they clearly do not understand or know anything about. F__k they make me angry.. I bet you the same person who wrote that comment is also the same type of person who drives in the right hand lane and sits 15km's under the speed limit then glare at you when you over take them even though your still going under the speed limit.
End rant.
F*ck me. I've just been trawling the Japan Yahoo car auctions, and I found 3 32 GTR's which were MINT! One was going for 24k AUD and had 21,000k ORIGINAL k's on the clock. It's been garaged for years! Only 1 owner with books to prove the k's!
And another one, had books to prove the dash board change over to prove it had 34,xxx k's on it.
So many people rant on about the k's being wound back, but there's plenty of Skylines who have little k's yet are original k's with books to prove it.
Most car ads also display the person doing a comp. test on the car, with pictures of each reading and they even show you the condition of the spark plug. Now that's what I call a decent car ad!!
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
