im being told fully bored out rb25 rehousing with hi flowed internal will make close to 300rwkw..
anyone else think this could happen? i didnt think the 25 turbo is big enough even after being bored out
yes this is true Bill at ATS does a 3076 high flow job to the RB25 he claims on bp98 he's had them upto 270rwkw and on E85 over 300
alot of people see those figures and think woooow! he claims he can get 300 out of this turbo wow....that's on 28psi and a f*kn shoe string tune just to get the numbers up there....by all means get an undersized, push the envolope turbo if you will....I'm awaiting some thread titles like...'why is my rb25 missfiring' 'someone help me with my rb25' and my favourite 'best place to get a rebuild'. Choose wisely the first time if your concerned about reliability.
No craig, i havne't driven my car in a week. hehe
Edited by Ryanrb25
I'm not having a go chris, im just having an opinion on something...I've had those turbo's and seen this shit man, on other peoples car's aswell....just giving you some info not from 'what ive read or just been told'. Not gonna lead anyone in the wrong direction.
Edited by Ryanrb25
steve are you talking about a gt30 with a machined out rb25 exhaust housing???
if you are they are f**kEN CRAP and waste of time !!!!!!!!...they defiently will only push 270rwkw
a workshop put this on my car and then blew the motor not long after on the dyno
Anyone know what a reasonable ballpark figure I'd be looking at to get two stockie 32 gtr turbos converted to steel exhaust turbines...?
I can buy some blown turbos but last quote I got for a rebuild (from an anonymous source) wanted $1250 per turbo.... for that price I can possibly get a pair of proper N1's....
MTQ and ATS get mentioned a bit, I haven't called them (usually because whenever I'm thinking about turbos its night time and theyre closed)... have any of ya'll had this done? How much did it cost you?
-D
Edited by Dohmar
It may well be possible to flow it through it...just maybe, but it would be very unsafe.
I asked my partner and he is a mechanic and said exactly what you said :D
Best you would get out of it would be 260/270kws and the boost would be up there.
R33 Chris why are you thinking that option for turbo?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
