pulled up next to a new vw turbo passat on the way home tonight, shit those things go like stink. i was pretty surprised by the way it mumbo'd along.
also had a dude in an old beat up corolla wagon attempt to drag me on main north road near elizabeth cop shop, ran a red light to get a head start, f**kin wanker.
yeh job sometimes helps lol...
well im in the market for a respray... and ideas? and also a new set of rims haha
still go Wine red Adrian but make it a bit red'er and a bit more metallic in it like my color
have you sold your rims yet???
i saw a gunmetal grey 32 at bp port rd today with the exact same rims as you
yeh he has my rims now...
yeh im gonna stay same colour but maybe with some blue through it?
i had a run with one of those and a vn ss lol. was pretty surprised at its speed too. not the vn tho... all piss n wind
7M's didnt have the right torque figures for the head from factory tighten them down a little more (there is info on the net somewhere) and its all sweet
with one of these
hahahah
yeah i had it tourqued down pretty damn tight, way over the factory spec.
7ms just have a habit of heating up alot around piston 5 n 6. in the end the block was munted (it had made a chanel between one of the water galleries and the 6th piston) so there was no chance some more twist could have saved it.
it now has a 1J in it :cheers: .... wish it was still mine
haha, wasnt gonna say i had a run against it, but yeah, shit, they really do move, i was expecting it to be all low down and lazy, but it just screamed along.
hey ben here is some stock gtr turbos with N1 turbines/steel wheels for 1300
whoops
http://www.skylinesaustralia.com/forums/Re...-N-t252112.html
Edited by r33 chris
spotted the black 33 with 34 front and flames down the side roll past the skate park at salisbury. looked to have a for sale sign in the window and a gtr badge at the back :( i was sure that thing was a gts
Thats EMS 334. My bus goes past his house every day, he has a new silver R33 GTR on trade plates too, and there was a rubbed-down R34 under sheets there a few weeks ago.
Went out north thru Salisbury, 'Lidabeth and Craigmore on the bike yesterday. :P
Man there are so many wankers who think they can drag off a bike :P Getting tired of it. Maybe my brother can move back down closer to the city again.
Yeah. I dunno how they can charge $1200 ea when I'll have the housings already removed and give them turbos.... put them back in thru someone else.... if i get this pair of blown gtr turbos and steel wheel em, it'll be regency friendly, but i cant be stuffed paying $1200 ea when I can get 2860-7's from ISC for around that price NEW
-D
Had a quick look at RB26 results: try this
18psi with high flowed steel wheels = 280 odd kws
18psi with -5s = 316kws .........
Only had a quick look - maybe there are others making more power on high flow steel wheels?? Post em up if you find them.....
Im running N1's in my GTR at the moment im making 296rwkws with stock injectors/afm's/fuel pump/fpr. They're great nice and responsive and the only problem i have with them at the moment is once of the oil seals has gone so i just bought a set of N1's that have just been completely rebuilt and will be fitting them soon. I was gonna get the Garretts but these came up and i have less chance of problems if i have to go to regency
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
