There's alot of talk of cranking over an engine without actually starting it to build up oil pressure.... noob question, but how do you do this?!
Unplug your crank angle sensor mate and crank it with the key, it will crank over but not fire, hopefully building some oil pressure....it probably wont build enough to read anything on the guage however...alot of people do this when a motor has been rebuilt and they need some sort of oil flowing through so they know the oil pump is primed.
Ok just got back from Dyno. Boost controller having trouble holding boost as it spikes to 25psi and by the end its at 19.5psi.
1st Run wheel spun its titties off so Pete had to tighten the straps more (made 279)
2nd run right up the top off the torque range it lost traction again and the graph fell away (made 323.8)
3rd run the heat had set in but still managed 323.2 and still wheel spun a touch up the top of the torque.
If i can get the boost to hold more stable who knows possible. I will post the dyno graph in the RB25 upgrade thread sometime today.
I owe all this to AD (aka180or200)who has done an absolutely brilliant job on tuning my car. Your a legend mate.
Needless to say i'm stoked with the outcome.
Loving the new found torque also
luke when ur 25 its even cheaper :)
i hate this dam weather so hot
and im still waiting for my bitch to get back so i can put her new shoes on my 360rwkw 4door build up track/drift mainly no more street car for me
P.S got back from wallaroo and caught some small snapper etc was nice there if i had my car back i would have taken it to 1/8 lots of squid snook gar tommy ruff and sharks etc.
got 50 pound braid on my snapper rod and the dam big arse snappers snapped my 50pound braid lol.
what would this fetch if i were to sell it the way it is ,
not exactly sure whats wrong with the engine but it still runs
stats
ENGINE:
RB26DETT conversion
RB26 sump w/transfer case sliced off
RB25 engine mounts
RB25 Harmonic balancer
HKS Intercooler with custom front mount position and solid piping
BLITZ 80mm S/S tuned front pipes
SIGNAL S/S (1.1mm and 7kg!) rear 80mm straight through carbon muffler
HKS Pod filters
Splitfire coil packs
TODA Racing clutch
TODA Racing 4.5kg Flywheel
CUSCO 2 way mech diff
IRIDIUM Plugs - 6's
R33 GTR fuel pump
SUSPENSION / BRAKING AND HANDLING:
SELBY rear 28mm sway bar
RACING GEAR coilovers
D1 rear camber arms
D1 HICAS lock
CUSCO front tension rod
Solid rear subframe bushes
D1 adj castor rods
PROJECT MU Slotted front rotors
TRW (LUCAS) brake pads all round
NISMO Front strut brace with brake stopper
GTR rear strut brace
BODYWORK & INTERIOR
Full body respray in Blood Orange
Satin Black bonnet and wing
SPARCO bonnet pins
NARDI Steering wheel
TRUST gear knob
SPARCO Spirnt drivers seat w/ BRIDE Rail
GReddy Profec B Spec II boost control
GReddy Turbo Timer
New Carpet
GReddy Boost Gauge
btw its my car AS IS , make me an offer , might be inclined to sell it .
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
