really?
... how much?
ok i'll post it up since you all want to know it cost $550 Its an Earls cooler measuring 12x6x2'' 19 row, Perma-cool adapters, Speedfow fittings and Speedflow hose. All good quality parts.
Looks good Chad - where you gonna put the oil filter??
I'll probably set it up similar to yours. I just dont want it to hang down to low, dont want it to be able to be hit if i run over a stick or something. Was gonna ask if you were maybe able to help me?? as i dont have spanners big enough to do up all the fittings.
sure - but I'm probably going away for 3 weeks on Tuesday. One week early. Thats one week less to get ready for the track day. Any of the next couple of days is fine :-) just might have to get out and about to grab swaybars and springs for a bit inbetween.
not easy being a big fella in a small fellas car.
and nissan oil filter placement is retarded. seriously. who the f**k puts a filter there?
haha that is nothing my friend....some of the machines at work are close to being impossible to get to and there are about 12 of them on one machine and 10 times bigger.
and for all the other chilli fans out there:
http://www.deathsauce.com.au/3amreserve.html
here is an excerpt of the heat rating of this :
Heat Index:
3 a.m. Reserve is not a sauce, it's an ingredient and is too hot to rate. If you're interested in buying this product, read the instructions below to fill out the disclaimer form mail it to address below or scan signed disclaimer and e-mail to us. You cannot receive this product without signing and returning the disclaimer.
he is not joking either.. i have had a couple bottles of mega death sauce in my time, and they are fk off hot (no im not a chilli wuss either :happy:)
I might leave you in peace to get your own stuff sorted then. I have to go back to work on Monday as well. I should have the tools at work i can use. if not, there are a few mechanics near my work if i get stuck.
IM GIVING AWAY SOME R33 SERIES 1 DOOR TRIMS (GOOD CONDITION) LEFT, RIGHT, FRONT, BACK FOR FREEEEEEEEEEE
IF THEY ARE NOT WANTED THEN IM GOING TO THROW THEM IN THE MINI SKIP ON THE WEEKEND, NEED GONE ASAP
PICK UP ONLY
DAN 0402541975
Okay, now that's kinda freakin' me out .. :) ... this is maybe 2 hours since I brought up doing a groupbuy at my work for baconsalt ...
(... I'm guessing this is due to Adelaide being a tiny place ... )
lol. yeah i heard about it around then LOL gotta love corporate email... im glad that news of important things sweeps adelaide quickly
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
