if it involves a pm it mustve been a fair whack.
got a clutch, now i need it fitted, recommendations/prices?
my mate shannon got his fitted by a local guy to me with a hoist in his shed, and there is also Just Jap @ jacobsen cress. they do excelent work great rates and i just had my water line replaced from the turbo with them :) from me
Thats cos you dont have a front diff sitting right under your oil filter, and you have skinny little arms :)
it would mostly be hard due to your fuel rail and plenum being right over the top
this is the cooler/relocation kit that i got (not using the relo kit cos i already have one).
HKS rip off, speedflow lines
$239
Question:
Braided lines are considered defectable by the police right? So what happens if you get Pirtek to do the lines. I'm sure their standards exceed AS and therefore meet ADRs if used on motor vehicles?
Reuben, I passed Regency with my oil cooler installed with Speedflow lines and Earls fittings... they didn't have a problem so long as it's mounted correctly and the lines aren't tracing all over the engine bay (ie. nice and tidy)
I'm sure Pirtek would do the lines also :)
My turbo oil line is braided from Pirtek. The water line is stock.
My auto oil cooler line is braided from Davies Craig.
My brake lines are braided from Maltech.
^^ this work exceeds stock standards so I cant see how its possible to be classed ultimately as illegal modifications
thats the thing, Ive got a massive list of mods but could only count a couple that need to be engineered. doing that atm, pretty much.
nothing wrong with getting other braided line made up by Pirtek, the only one that they can't do are the brake lines and i'm pretty sure that if you ask them they will refuse to do it anyway. If you get another place to make up brake lines and they don't put the ADR sticker on them then they are illegal and you will fail an inspection.
Here's my oil feed line the Pirtek made up;
Hence why (as radical as it is) my bike is completely ADR approved.
As much as I've been tempted to remove certain stickers for show purposes (see below), I haven't or else they are no longer approved brake lines.........they could then be anything!
Don't suppose anyone's got banjo bolts for the front R33 calipers lying around, or know where I can get them (most wreckers prob won't part with them)?
Wanna fit the 4 pot calipers and ditch the 2 pot ones.
:D
try Steve at Nisswreck or Pete Hall at Jap Motorsport Roo
Thanks Pete. Was going to drop in to Nisswreck on Saturday if I have no luck with the brake mob on The Parade today. While I'm out there, I'll swing past JMS. Going to lunch shortly to do all that. :D
so ive found out that my engine in my car is from an R32 GTR V-Spec and was purchased from Autotech of all places , and had 80,000kms on it at time of being swapped into my car which in actual fact means its done over 100,000kms , never been serviced and had the speedo in the half cut wound back.
lol. yeah i heard about it around then LOL gotta love corporate email... im glad that news of important things sweeps adelaide quickly
As someone who moved here from interstate, it constantly surprises me how tiny Adelaide is - especially with stuff like this. You find out that your neighbour knows a guy you work with, or that some guy you met on the internet knows a friend of yours, or ... the list goes on .. It boggles the mind :P
Nene has some serious real estate. :P
A project I'm working on at the moment, and I found this:
"Nene Valley". Not far from "Blackfellows Caves"! :P
Ah ... back to work.
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
