anyone here need there guards rolled? Getting my hand on a guard roller next week to roll chad's and possibly my car. If i do a good job on my car, would anyone been keen to get there guards rolled?
Hey ppl, I haven't been on here in ages... Pretty much my Skyline has been in and out of morpowa with cooling and suspected coil issues.
Making me broke in other words. Cooling is all fixed but ever now and then it will drop the first cyl making it run on 5. Diognostic said something to do with ignition something... Has anyone had this problem?
Morpowa are looking more into it
. So... Anyone had this before?
Thanks SAU ;)
Would that make it do it all the time or now and then? Engine light comes on too...
They seem to think it could be from water and coolant getting in the coil...
It's a big job just to get to them on a non turbo.
if water or coolent is getting in there check for a split hose around the top of the motor. I found one in mine i had to replace it..
I had to take mine out roughly 3 times as i tryed new spark plugs and they didnt work, then i tried wrapping the coils in tape and that didnt work, then i put the splitfires in and that worked. Only takes me roughly 10mins to change the plugs/coils now.
Engine light might mean a loose connection somewhere, or could be the coils. Bad coils will make the car chug every now and then but sometime seem fine.
Engine light comes on whilst still running?
Misfiring really comes down to a few basics. It's either the spark plug itself, the coil, ignition amp, ECU issues, or any of the wiring and connections between the listed components. It's just a matter of working through each item and removing it from the equation until you pin point the problem.
I would start with identify which cylinder it's dropping and then go from there. If the plugs are all fresh and aren't being continually re-fouled then look at swapping the coil over from the cylinder that is dropping out and see if the problem follows - it might take a bit of time if the problem is intermittent (intermittent problems are a PITA).
Make sure you also clean the coils and the area in between the rocker covers and ensure they are all free from moisture. If moisture (from coolant or any other source) keeps appearing after you've cleaned it thoroughly then something is certainly amiss and it's not a coil problem!
I've got 6 factory RB25DET coils in perfect health sitting in my shed that can be used for testing purposes - unfortunately they probably won't help on a R34 RB25DE.
Good luck.
Good luck.
Yeah engine light comes on while it's running like that then goes off when it's back on 6.
The coolant issue was sorted with the new cooling system so I know how it could have got wet.
Morpowa said it's a big job to get to them? Taking off water lines and stuff... Like a 2 hour job.
I think it may be coils as luke said cos that's what it does... Sounds good for a Rex but when ppl see it's a skyline it's embarrasing!
Its not a 2hr job lol u dont need to take the inlet manifold off, just the throttle body and use a whole heap of sockets. If u get splitfires and need a hand yell out and i'll do it.
Mitch, maybe the guy who sold you the car blew the previous rb26, got a cheap half-cut, threw in that rb26 and then sold it to you?
Crazy stuff dude.
nah he went from an rb25det to this rb26dett
will hopefully know whats wrong with it tomorrow, id LOVE to buy an rb26 from an R34 gtr but that wont happen.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
