lol yeah TPG even have crap speeds my son is with TPG in canberra and on the adsl 2+ and only downloads at about 300k whilst im on extreme cable and getting 2500k :D
only thing is he has huge down load limit i get 12gb and my uploads are counted about time telstra gave us 25gb or something
Well Steve my Interweb speeds are all over the shop :D
I have ADSL1+ (as I am on a RIM so can't get ADSL2 even though I am a whole 7km from the city and under 1km from my exchange).
Mostly I run at about 2.5Mb (as I am when I tested now), but check this out from a few weeks ago:
You read right - slower download than upload - 136kb/s - just over double the speed of dial-up - and I pay $100 a month for the privilege.
I often test at under 1Mb/s, even though I changed from ADSL1 1.5Mb/s to a 'faster' plan (where they won't guarantee a minimum speed). Joy. Not.
lol I easily manage to blow my 40Gb per month .... 3Tb of HDDs and I am nearly full so about to buy another couple .... Usenet ftw
All that porn...
http://au.youtube.com/watch?v=4pn4kZyqVRU
Grab your dick and double click for porn porn porn!
-D
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
