lol, has anyone seen the southpark episode with barak and mccaine in it? i'll go find the link now
edit: found it, must watch - f**kin hillarious!
http://www.southparkzone.com/episodes/1212...Last-Night.html
Edited by rhys5169
I was actually going to come to villis this friday but my thermo fan has shit itself.
Im back on 6cyl from replacing just the 1st coil ;)
Im so tired of not being able to drive far.
Someone come fix my fan!! it keeps shorting and blowing fuses..not spinning quick... booked in for Tuesday at the auto electrics but I just want to driiiiiiiive!!!!!!
anybody want some hormones?? i'm so friggin sick of them :(
i decided to clean abit of my room and found a dead Huntsman, i think i killed it with a box
but without knowing it was there ;) lol
Edited by pokie
Adrian you should be able to get 34 gtr wheels for around 1600-1800 with good tyres, OR get some CR KAI for around 1600 with tyres.
Just depends how soon u want them.
Adrian when you are buying 2nd hand rims with good tyres from a Jap importer make sure you check the date on the tyre saying when it was manufactured, when i looked at some r33 GTR rims at Japanese import spares the rims had good tyres but the date said they were made in 2006 and they wouldnt even budge on the price coz of it so i didnt buy them
Why would it matter when the tyre was made?
If it was kept out of the weather and not gone through loads of heat cycles there still good :) What was the tread percentage??
If the rims are worth the money the tyres are a bonus...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
