lol, has anyone seen the southpark episode with barak and mccaine in it? i'll go find the link now
edit: found it, must watch - f**kin hillarious!
http://www.southparkzone.com/episodes/1212...Last-Night.html
Edited by rhys5169
I was actually going to come to villis this friday but my thermo fan has shit itself.
Im back on 6cyl from replacing just the 1st coil ;)
Im so tired of not being able to drive far.
Someone come fix my fan!! it keeps shorting and blowing fuses..not spinning quick... booked in for Tuesday at the auto electrics but I just want to driiiiiiiive!!!!!!
anybody want some hormones?? i'm so friggin sick of them :(
i decided to clean abit of my room and found a dead Huntsman, i think i killed it with a box
but without knowing it was there ;) lol
Edited by pokie
Adrian you should be able to get 34 gtr wheels for around 1600-1800 with good tyres, OR get some CR KAI for around 1600 with tyres.
Just depends how soon u want them.
Adrian when you are buying 2nd hand rims with good tyres from a Jap importer make sure you check the date on the tyre saying when it was manufactured, when i looked at some r33 GTR rims at Japanese import spares the rims had good tyres but the date said they were made in 2006 and they wouldnt even budge on the price coz of it so i didnt buy them
Why would it matter when the tyre was made?
If it was kept out of the weather and not gone through loads of heat cycles there still good :) What was the tread percentage??
If the rims are worth the money the tyres are a bonus...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
