Question,
Just put my coilovers in. I had a wheel alignment done about a week ago, so my question is, do I need another one?
Took the car for a drive and it seems to drive as straight as before.
Question,
maybe you do! my car went straighter with coil overs in but the result when i got it alligned said otherwise
what sort of coil overs did you get?
I might just as well go and get one anyways.
I got a second hand set of Bridgestone NPG's in mint condition. The ride feels very firm but not too bad over bumps either. Only problem is they're set pretty low and I don't have the wrenches to raise the car up a bit.
Edited by tx3_90
they feel good?
what sort of settings can you play with?
WOOT 1000 POSTS !1!111!11!!!111!!
Try this
already been on it mate , also found another removal guide in pdf form but they all show removal with the gearbox
is it possible to remove the engine and leave gearbox in the car still ?
also , wheres the best place to get an engine hoist and stand for a reasonable price?
cheers
I'd be interested in the PDF, could you link me to that?
Why you keen on removing the motor yourself? Save costs on rebuild?
here it is
its for a 32 GTR but i cant imagine it being all that different ?
yeah , i cant afford to take it somewhere to get rebuilt so me and my dad are gonna do it our selves :sick:
Nah, should be pretty much the same!
Old man ever rebuilt a motor before or you going in blind? Be careful and make sure you do some research before you start. A mate of mine did his 25 himself having never rebuilt a motor before and did a great job on it!
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
