Sorry for the coming long post, but I received this excellent 'on topic' email from my Mum just yesterday .... unfortunately I think a lot of guys on here will experience this in the coming 2 years of recession under the Krudd government. :)
The moral of the story is that rather than give below average income earners $1k to blow on pokies, booze, turbos etc (which is exactly what happened last handout and only benefited the hoteliers of Adelaide, not the economy in whole whatsoever), the govt should ease tax on businesses, so that 1. they manage to stay in business through the tough times, and subsequently 2. many people actually keep their jobs as a result of the businesses not going under and massively effecting the economy.
what a revelation Andrew.......could not have been said any better!!
Do you know that the majority of Australia's workforce is employed by small business, not big industry?!
Smarten up people and stop misdirecting your winging & whining to your boss but rather the gov.
On the money nightcrawler.
However I feel most people are entirely blaming Krudd for these troubled times.
Has alot to do with China. Alot to do with the US.
I feel Krudd took over government in very different times. Very different to the early 90s etc.
Its a different world. I wouldnt want to be in his shoes
At the end of the day we are still a lucky country. So I try not to whinge too much.
True. good fact.
But; The government is handing out lump sums to help the small businesses.etc (so they say) People will spend more with the lump sum. I agree some people will just spend it on the pokies.
In contrast; Buying a turbo. buying a swimming pool. Getting your car fixed up. are all helping small businesses. to a certain degree.
don't know about us living in the lucky country anymore......that may have been the case a few years ago
Did anyone see the latest figures on home affordability around the world??
Only 10 years ago we were amongst the most affordable places on the planet to own a home, we have now moved up to around the top 10 of the least affordable on the planet......and I'm talking Adelaide here, not just Sydney!!
sled did you read alexander downers collum in yesterdays advertiser? its the only thing worth reading in that shocking paper, he finally let loose on what he thinks of rudds handling, very good read. i'll see if i can find a web link
and mind you, they are referring to an average household income (which usually means X2).
Anyone have any idea what the so called average income is at the moment........judging by the average age on these boards, only a small % would be on it and even less over it...........and if you don't have a missus to contribute, you're stuffed!
Here's one of the quotes from the above link:
The Deposit Power/REIA Affordability report for the September quarter found 36.6 per cent of household income was needed to cover average home loan repayments.
That tells me that it would be close to 100% of some of your wages! :)
no I didn't see it bud
this whole thing has me shaking my head. everyones going on about how awesome its going to be to get $1000, but they dont realise the long term cost of this. its billions of dollars in deficit over the next couple years, surely people can see the problem in that?
Thats deff one point alot of people dont address.
Without a partner or business counterpart how are you supposed to afford buying a house.
I dont go back on my word when saying we are a lucky country.
But I must agree that its very hard to afford and pay for a house. Almost seems you have to have no life and sit at home and constantly pay off your mortgauge with a lovely interest involved.
That's an awesome letter there Andrew... read it to my olds, they agreed 100% and have added it onto their mailing lists to send out to others. It's sad that people can realise this but somehow the government doesn't, or doesn't want to
but what can we do about it? the Majority of the population voted him in!
here, here!
ohh bull, the liberals just rode a wave of success, and they didn't capitalise when they had the oppurtunity to do things to help soften the blow when the eventual bust came.
And what goes up MUST come down it's simple.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
