Hahahahahah so you're saying if the liberals were in power the global financial problems wouldn't of happened. This is easily the post of the year and it's only feburary. Hate to break t to you but with the current situation I'll think you'll first d whoever is in power would have some sort of deficit in the budget.
+1
And what do the liberals do? They sit on a pile of money and do nothing. Part of kruds plan is to invest in infrastructure which will create a few hundred thousand jobs. We are not that isolated if we were we getting be getting this cold after the USA sneezed.
stol came over last night to help put the car up, cheers Andy muchly appreciated
after spraying him with rp7, and getting a screwdriver stuck in the cat for 20mins, finally got a .8mm round hole thru the cat
just want to release enough backpressure to stop boost drop
seems to have worked mostly, probably need to do again but slightly larger say little finger width thru the centre
sounds like a fair bit of work. one thing though, hole in the cat probably makes it effectively useless. just take it to an exhaust shop and have it modified completely.
ive been up all night. night shift = days off are stupid. might buy an intercooler just for something to do today.
also, omfg!
stock z body (pulled rear gaurds) with 18*10 -7 front and 18*12 -13 rear... do want.
hey i didn't mind that red Volvo on top gear last night does that mean i have homicidal tendencies towards stagea's, should i see my doctor if pain persists :):D
naa you'll come to your senses when the heat goes......hot weather can make you delirious :)
I'm showing my age here, but my mum would always tie a sixpence in the corner of my school hanky and told me to keep it for a rainy day.........moral of the story is, better to have it than to owe it.
Do you actually understand how he plans on going about this......cause he doesn't, not judging by the way he has hit my business since Johnny was shown the door.
lol Brendan, expect a visit from the RSPCA :(:P
by the way, .8mm is only 32 thou.....the size of a needle hole?
Oh goody! A non-political topic. :(:D
I'm thinking of getting another cooler too ... a stealth unit to replace my home made jobbie :)
figured id change it up a little. keep my adoring public guessing. :)
i just want to replace the tiny stocker. put a couple borrowed temp probes in piping both pre and post-cooler just to see how it worked. and well, it doesnt work too well. and whatever kit i buy with be copping a can of crinkle coat + satin black to the piping and a can of satin black to the core itself. mmmm, stealthy.
Edited by scandyflick
A TV/electrical question:
I have a Samsung 32 inch flatscreen LCD in my bedroom. I bought a HD set top receiver box for it, and a cheap HD aerial from ebay. That didnt work, so yesterday i bought a dick smith HD indoor/outdoor aerial. I connect it, tune the tv, only picks up SBS through the set top box. SBS, SBS HS, etc etc. then i plugged the aerial straight into the tv itself, and tuned that, and it picks up SBS clear as day, but 7, 9 and 10 are all snowy. Would it be better to mount the aerial outside? Im so over snowy tv. Could it be the tv itself?
Brendan just bite the bullet and get your self a AMperformance high flow cat you wont regret it
i think there about $360ish will confirm price when i can get in contact with him, and you will probably pick up a couple of psi from it being able to breath
edit price confirmed $360
Geez pete you are old bud lol
sixpence isnt that like centuries ago...time for using dollars and cents :(
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
