as i drive home from shopping i was exiting the carpark to run into a cop who's just entred! so he decides to do a u bolt and in that time doing 60 i managed to get some distance and turned into my street and lost him! harrrr thank god for those blind corners
Ok, so having read the recently closed "cruise for a cause" thread... is there actually still a cruise???? I don't really want to drive from victor to arndale to be the only tosser in the car park.
If anyone knows pm me.
soooo i guessing im the only person heading to drifts this saterday haha
everyone i talk to says their not going.
might have the whole track to myself :thumbsup::wave:
I did a track day once where there was only 3 bikes in my group. No dickheads :D
might have the whole track to myself :D:D
Fk I want to get back out there, it's been a year now :)
Which means it's also been a year since I got rid of the 100. I reckon I'm doing well not to have clocked out early :(
usually me and dan have whored up the wasteland by now, WHERE U BEEN CRONIC
Whats wrong Damo, can't you be a whore on your own? :(
Edited by RubyRS4
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
