I think you'll take back that statement once it's been rebuilt...
MAYBE.
its just finding someone to build it and finding a job that doesnt require a car so that i can raise more money
how sad , my race weapon is my daily , ha!
im gonna kick myself for suggesting someone else actually do this,
but have you considered applying at the casino, mitch? weve got pretty high staff turnover at the moment, so were constantly hiring and training new staff, first few weeks sucks with no pay (training, not sue how thats changing with the eb's), but once youre through that, its close to $20 an hour, for as many hours a week as you want...
Edited by scandyflick
i have thought about it but i dont want to deal black jack or deal with people on a retail side of things etc as.
what sort of job's are there available because the only ones ive seen on the Sky City site is experience croupiers and HR Administration job's ;/
MAYBE.
no luck with fours n more?
most croupier jobs are no exp necessary. but theres main cage cashiers, security, gaming machines, valet parking, anything related to food and bev, just jump on the website and fire off some apps, its shit work, but if you need quick money, well...
cheers dave , will give it some consideration :thumbsup:
i dont like em. lol unless they are the cafe primo ones lol
lol Your not alone Cara, I cant stand pancakes either, gut bombs!!!! :)
give me waffles anyday..lol :O
and Damo my R34 front lip goes into production in a few weeks , all CF and fully functional venting..?
be up for some orders after a checking the arc on another front bar? cost TBD but hell of a lot cheaper then Nengun and better venting.
hope to have it done for the show and shine
Guest CleanAndSimple
know this is not that wanted section but nobody reads it anyway,
by any chance anyone got any 6" or 6.5" speaker covers, like just the plastic covers, my stock skyline ones have broken to pieces :) dont really want ugly holes there (Y).
will pay for them, just don't have to cash to do my sound system.
Hey,
Does anyone know how to get the faded stuff off the headlights when its on the inside? I use cut and polish to make them clear on the outside but one of them must have had mosture on the inside at some stage....
Cheeeeeers
Penny,do you have a photo of it?
it has a broken seal and needs to be removed and split apart to fix properly, dont attempt unless your confident in repairs, very fragile and expensive to replace if done wrong!!
to fix them to perfection use aircraft windscreen polish, or megulars m105 works pretty good to rid the haze followed by plastic polish.deeper scratches can be sanded out with 2000grit wet sanding followed by the above.
to dry them pop out a globe and use a heat gun or hair dryer on low heat, then put the globe back in.
hope that helps
Troy
I swear u guys dont know what you're missing. Some pancake recipes are shite (and dont even compare instant pancakes to the real shit).... you get a good recipe for home made french crepes, you wont be going to work that day...
waffles are cool too but i'd rate a good crepe/pancake over waffles anyday. sounds like u guys have been eating pikelets instead ;D
-D
pretty sure i have some, silver with a cross pattern no mesh . free to a good home
or i would suggest any car audio shop, they normally have boxes under the workbench overflowing with them?
-D
pancakes and pikelets, both foul..lol
my grandma makes some pancakes with 7/up or mtn dew in them. the bubbles make the pancakes thin and slightly crispy when they pop while cooking. much better then thick pasty doughy ones. some old fossil recipe but still not that crash hot on pancakes.
Edited by sapphiregraphics
man thats just lazy, shes using the soda in place of bicarb ;\ disgusting
a good pancake is rubbery and flexible... light but not aerated.... when u put salt and aeration into a pancake it becomes a pikelet (and i find them damn near inedible)...
imho the thinner the better - thick, aerated pikelets are like uncooked bread, which is a total degustation misnomer
-d
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
