Well just got my car back with some new goodies on, she's sweet as! Props to Andrew (Blue32) for the help and Pete (SLED) for the parts :banana:
I'm off to bed, night all :D
no probz bud..........don't forget I've still got a Mines baffle kit for you
I researched the brake cylinder stopper a bit today, and had responses from "nope, dont bother on a street car, no difference" to "wow i felt the difference straight away!" I guess with more rigidity in the cylinder your always going to get a better pedal feel.
It depends on the car too. I don't know if 34s have the same issue with firewall flexing as the 32's do. I know the flex is pretty notorious on 32's and yeah, definately noticed the difference the moment it was put on... it wasn't expensive either, a smidgeon under $200 iirc..
-D
recommendations?
full house (the car is auto sadly so pfc is off limits...)
piggyback
remap
note, i don't have a lot of money to play with atm saving up for paintjob.
thats not entrily true there is a mod you can do
Mate i would be putting my money on coil packs
Whack it on the dyno and you will find the reason in about 5 minutes
GWW can bench test it i imagine most other workshops can too
Props to Martin Donnan and his article in boost mag about the r35 gearbox. Learnt a hell of alot from reading it, well constructed and very informative. Good to see you guys have the one up on Nissans "secret formula" gearbox fluid.
Can anyone suggest a good oil catch can?
And what's the difference between this:
http://justjap.com/store/product.php?produ...=360&page=1
And this:
Apart from price and size of fittings?
Time for me to start investing in a few mods for the GTR!
And this:
Fairly sure the first can be mounted above or behind the rocker cover. I have the d1 spec catch can in mine.
yeah, im up to page 35 on that thread. been cruising the rest of the site at the same time. its giving me ideas. lol. set of satin black bbs rs 3pc wheels with gold nuts... mmmm...
:EDIT:
oh, if only i had the money...
:EDIT:
extra win.
Edited by scandyflick
And this:
600ml coke bottle, garden hose, gaffa tape
problem solvered
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
