i would say go with the RB25 Mitch
that way the can will be legal and wont have much hassles
but your call really
if the motor just needs a small scale rebuilt then do that
whatever you do mate goodluck with it and hopefully see you out and about soon
Im not sure what the law is but if you change back to a 25 you may need to go through regency so that they can approve the new engine number to make it legal. You may want to ring them and find out.
At work today thinking about next yr. Wondering if i should save up spend 10k on a engine or spend a month holidaying in Japan.
hmm hard choices.
Don't forget a 1/3 of that has to come my way :D
Pete it was finnaly good to meet you and have bit of a gas bag about the old Valiants!
yeah it was good James, cheers for the chat
I would also like a washer bottle that fits in despite my ic piping. I assume if Damo got one made up it would fit my car too? I can supply my oem washer bottle motor if he wants to integrate it (which would be preferable).
yeah, he'd do that with the OEM gear (basically it would be a solid replacement to the factory plastic ones)
oh, and cos i can
man i still lose my shit every time i watch this :(
:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
Getting given 10 massive bags/boxes full of baby goods, and having to sort them out while massivly hungover= FAIL
finding 6 xxx DVDs in the bottom of one of the boxes, without wendy noticing = WIN!
i cant believe how many cops were out last night as it was!!!!! sooo many more than friday night
i know, i came from down pt noarlunga, there was an drug test van as ya head down into porties (just afta ya come round from murray rd), plus 2 separate RBTs on Anzac Hwy
surprisingly no cops at the bay or anywhere near hindley / rundle. most of their hindley fun has been taken out by closing that section off on a sat nite
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
