Ben you've made half a point and have made it well.
All I can say (can't speak for the other Mods) is that certain older (non car related) threads will run their term and will then be appropriately locked or continued in Wasteland.
ps.
dale.. i wanna talk to u about setting up a reliable ca18det for my keto.
Talk away, It pretty much the luck of the draw though as i was saying it depends on the history of the engine. So unless you are going to start with a rebuild then there is no guarantee that the engine you have will be reliable. The thing is that CA's are relatively cheap to rebuild, for around $2500 + machining (but i have some parts already) i can have a bottom end that will easily hold 250-300kw+
Edited by D_Stirls
Pete I think the answer is to create an Off Topic SA section so people can create nonsense threads and and every one else isn't exposed to them. Do what NS does and make the section a non post count section, hell if this had been done from the start Damo and a few others would only have 5 posts and not the thousands currently they have (not that post count means anything).
We are all member of the "modified/performance" car community but that doesn't mean that we have to always talk about cars.
Amen to that.
CRoNic...
got link to that ca18det on ns.com?
Ahem, I think it was I that alerted you to said CA package :(
Just finding it now, but NS is running like a CAde auto with fked coilpacks at the moment....
Here 'tis
Edited by AndrewJZX100
i founds supecharger!!!!!!!!!!!!!!!!!!!!! zomg!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
who makes it ? does CAPA sell them out of Berri?
that would sound hot, whine at the lights...lol people wouldnt have any clue what is lurking under the bonnet...lol
Jason Gilespie:
"You don't need to warm up your car. Warming up your car, in my mind, is a waste of time if you're running Castrol oil"
Good on ya, Jason.
(that was on a Castrol commercial just on)
Hi Jason
Sell out much?
The day I take engineering advice from a cricketer is the day I trust my root canal to a f**king demolitions expert.
Thanks for the fish
Love
Dohmar
not sure about CAPA........this is thru yella terra
cool, you might try calling CAPA, they do a lot of chargers and being somewhat local ..????
http://www.capa.com.au/kits.htm
do you have a link to yellow terra, like to see how they mount it and have access to pulleys still ? and have working a/c still?
I like it when I make only half a point. It seems to synchronize the yin and the yang.
Better to make half a point and do it well than make a whole point and entirely f**k it up
I suppose.
-D
Samir Godzilla,
If you can't go thru with a deal on the sale of my Stagea which you started with your offer, then don't go shopping for cars and don't waste my time.
BTW an R33 is not a Stagea :D
You've been reported to the mods.
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
