Ben you've made half a point and have made it well.
All I can say (can't speak for the other Mods) is that certain older (non car related) threads will run their term and will then be appropriately locked or continued in Wasteland.
ps.
dale.. i wanna talk to u about setting up a reliable ca18det for my keto.
Talk away, It pretty much the luck of the draw though as i was saying it depends on the history of the engine. So unless you are going to start with a rebuild then there is no guarantee that the engine you have will be reliable. The thing is that CA's are relatively cheap to rebuild, for around $2500 + machining (but i have some parts already) i can have a bottom end that will easily hold 250-300kw+
Edited by D_Stirls
Pete I think the answer is to create an Off Topic SA section so people can create nonsense threads and and every one else isn't exposed to them. Do what NS does and make the section a non post count section, hell if this had been done from the start Damo and a few others would only have 5 posts and not the thousands currently they have (not that post count means anything).
We are all member of the "modified/performance" car community but that doesn't mean that we have to always talk about cars.
Amen to that.
CRoNic...
got link to that ca18det on ns.com?
Ahem, I think it was I that alerted you to said CA package :(
Just finding it now, but NS is running like a CAde auto with fked coilpacks at the moment....
Here 'tis
Edited by AndrewJZX100
i founds supecharger!!!!!!!!!!!!!!!!!!!!! zomg!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
who makes it ? does CAPA sell them out of Berri?
that would sound hot, whine at the lights...lol people wouldnt have any clue what is lurking under the bonnet...lol
Jason Gilespie:
"You don't need to warm up your car. Warming up your car, in my mind, is a waste of time if you're running Castrol oil"
Good on ya, Jason.
(that was on a Castrol commercial just on)
Hi Jason
Sell out much?
The day I take engineering advice from a cricketer is the day I trust my root canal to a f**king demolitions expert.
Thanks for the fish
Love
Dohmar
not sure about CAPA........this is thru yella terra
cool, you might try calling CAPA, they do a lot of chargers and being somewhat local ..????
http://www.capa.com.au/kits.htm
do you have a link to yellow terra, like to see how they mount it and have access to pulleys still ? and have working a/c still?
I like it when I make only half a point. It seems to synchronize the yin and the yang.
Better to make half a point and do it well than make a whole point and entirely f**k it up
I suppose.
-D
Samir Godzilla,
If you can't go thru with a deal on the sale of my Stagea which you started with your offer, then don't go shopping for cars and don't waste my time.
BTW an R33 is not a Stagea :D
You've been reported to the mods.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
