Ben you've made half a point and have made it well.
All I can say (can't speak for the other Mods) is that certain older (non car related) threads will run their term and will then be appropriately locked or continued in Wasteland.
ps.
dale.. i wanna talk to u about setting up a reliable ca18det for my keto.
Talk away, It pretty much the luck of the draw though as i was saying it depends on the history of the engine. So unless you are going to start with a rebuild then there is no guarantee that the engine you have will be reliable. The thing is that CA's are relatively cheap to rebuild, for around $2500 + machining (but i have some parts already) i can have a bottom end that will easily hold 250-300kw+
Edited by D_Stirls
Pete I think the answer is to create an Off Topic SA section so people can create nonsense threads and and every one else isn't exposed to them. Do what NS does and make the section a non post count section, hell if this had been done from the start Damo and a few others would only have 5 posts and not the thousands currently they have (not that post count means anything).
We are all member of the "modified/performance" car community but that doesn't mean that we have to always talk about cars.
Amen to that.
CRoNic...
got link to that ca18det on ns.com?
Ahem, I think it was I that alerted you to said CA package :(
Just finding it now, but NS is running like a CAde auto with fked coilpacks at the moment....
Here 'tis
Edited by AndrewJZX100
i founds supecharger!!!!!!!!!!!!!!!!!!!!! zomg!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
who makes it ? does CAPA sell them out of Berri?
that would sound hot, whine at the lights...lol people wouldnt have any clue what is lurking under the bonnet...lol
Jason Gilespie:
"You don't need to warm up your car. Warming up your car, in my mind, is a waste of time if you're running Castrol oil"
Good on ya, Jason.
(that was on a Castrol commercial just on)
Hi Jason
Sell out much?
The day I take engineering advice from a cricketer is the day I trust my root canal to a f**king demolitions expert.
Thanks for the fish
Love
Dohmar
not sure about CAPA........this is thru yella terra
cool, you might try calling CAPA, they do a lot of chargers and being somewhat local ..????
http://www.capa.com.au/kits.htm
do you have a link to yellow terra, like to see how they mount it and have access to pulleys still ? and have working a/c still?
I like it when I make only half a point. It seems to synchronize the yin and the yang.
Better to make half a point and do it well than make a whole point and entirely f**k it up
I suppose.
-D
Samir Godzilla,
If you can't go thru with a deal on the sale of my Stagea which you started with your offer, then don't go shopping for cars and don't waste my time.
BTW an R33 is not a Stagea :D
You've been reported to the mods.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
