went to funkoars tonight. ive never seen so many full blown punch ups in a pit before.
nor have a i ever seen a vn do ringies in a bp forecourt before.
nor have i ever seen star force rock up en masse to a music event.
interesting night.
welcome to the dirty south lol, can garuntee more than half that croud woulda been good ol morphies blokes throwin punches
i am not happy with the way the car corners at the moment! turn in yeah it's ok the front feels solid but the rear twist under harsh cornering! i had a look at r34's to why they'feel solid and it turns out the reinforced the rear with some sort of brace behind the rear seats! basically there's too my flex more my liking!
isnt there a dedicated thread for that?
yes, but theres nothing saying i can't post it in here.
well just come back from down the street, there was a heap of people waiting on the side of the road
just waiting to see some bikies. there was a heap of police aswel, think there was 3-4 bus loads of police with
riot gear lol, i swear they had more police assistance than the Queen when she was here haha
sway bars help with body roll! but you can get a hint with the rear that it flexes while turning at higher speeds under acceleration
Replace every bush in your suspension with nolathane or alloy bushes, bracing the chassis wont do much if your still have rubber flexing in the suspension.
Have you got cradle bush spacers? If you haven't then what you are feeling is the rear cradle bushes deforming. Get some urethane pineapples and it will improve the feeling 100%.
Ok so having a weird strange problems with my car. Had baffle plate in coz of defect and have just recently put back in my stock ecu with remap including gtr injectors which are still in the car.
My car will run on low revs going thru the gears but as soon as i put my foot down to get it a squirt shoots massive black smoke out and doesn't move literally looses all power until i back of and slowly increase.
HELP PLEASE. I've changed plugs helped for a little
P.S i can still rev the s##t out of it while in nutral with nothing
Done the usual clean/check of the AFM? Could cause a similar problem, obviously the remap supports the bigger injectors yes?
Also, maybe an IC pipe has come off, loosened or one of the silicon joiners might have a crack in it. Check them all, you'd be surprised. Me and Steve both had a similar problem, that was the cause
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
