went to funkoars tonight. ive never seen so many full blown punch ups in a pit before.
nor have a i ever seen a vn do ringies in a bp forecourt before.
nor have i ever seen star force rock up en masse to a music event.
interesting night.
welcome to the dirty south lol, can garuntee more than half that croud woulda been good ol morphies blokes throwin punches
i am not happy with the way the car corners at the moment! turn in yeah it's ok the front feels solid but the rear twist under harsh cornering! i had a look at r34's to why they'feel solid and it turns out the reinforced the rear with some sort of brace behind the rear seats! basically there's too my flex more my liking!
isnt there a dedicated thread for that?
yes, but theres nothing saying i can't post it in here.
well just come back from down the street, there was a heap of people waiting on the side of the road
just waiting to see some bikies. there was a heap of police aswel, think there was 3-4 bus loads of police with
riot gear lol, i swear they had more police assistance than the Queen when she was here haha
sway bars help with body roll! but you can get a hint with the rear that it flexes while turning at higher speeds under acceleration
Replace every bush in your suspension with nolathane or alloy bushes, bracing the chassis wont do much if your still have rubber flexing in the suspension.
Have you got cradle bush spacers? If you haven't then what you are feeling is the rear cradle bushes deforming. Get some urethane pineapples and it will improve the feeling 100%.
Ok so having a weird strange problems with my car. Had baffle plate in coz of defect and have just recently put back in my stock ecu with remap including gtr injectors which are still in the car.
My car will run on low revs going thru the gears but as soon as i put my foot down to get it a squirt shoots massive black smoke out and doesn't move literally looses all power until i back of and slowly increase.
HELP PLEASE. I've changed plugs helped for a little
P.S i can still rev the s##t out of it while in nutral with nothing
Done the usual clean/check of the AFM? Could cause a similar problem, obviously the remap supports the bigger injectors yes?
Also, maybe an IC pipe has come off, loosened or one of the silicon joiners might have a crack in it. Check them all, you'd be surprised. Me and Steve both had a similar problem, that was the cause
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
