Yeah thats what im planning to do, I just cant find what im after.
I looked at one at Torque cos they would trade in my car but the guy couldnt answer ANY of my questions so I walked away.
I dont want to sell mine then not find anything and be carless. I think I want to keep my rims too. Haha I hate buying and selling, its such a pain in the ass!
Nice PC specs there Brendan.
@Madaz: You can flash that P5e board with a Maximus or Rampage BIOS. It gives some nice oc'ing features, I flashed my Maximus with the Rampage BIOS and it definitely clocked higher.
cheers, yeah i7 is sweet (same goes with the mobo and ram - gift, yay)
yeah the asus p5e can use the Maximus Formula bios for sure, however it is updated to the current bios spec.
anyone want WD 320Gb (3-off in all) ? cheap make an offer, but been error-prone for me. desktop weights atm.
Cara! I gave you advanced warning about that and you still fell for it :sweat:
ben sent it via msn............didnt recognise the url for it
Weirdest shit - I have a MASSIVE craving for peanuts at the mo :)
andy are you pregnant? :)
:) i miss all the good shit
but meh, i bet it would have been funnier in japanese :sweat:
sorry, but no.
it doesnt get much better than crack whores, meth heads, single wheel peels, near collisions, and swearing that you can hear from a block away.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
