Yeah thats what im planning to do, I just cant find what im after.
I looked at one at Torque cos they would trade in my car but the guy couldnt answer ANY of my questions so I walked away.
I dont want to sell mine then not find anything and be carless. I think I want to keep my rims too. Haha I hate buying and selling, its such a pain in the ass!
Nice PC specs there Brendan.
@Madaz: You can flash that P5e board with a Maximus or Rampage BIOS. It gives some nice oc'ing features, I flashed my Maximus with the Rampage BIOS and it definitely clocked higher.
cheers, yeah i7 is sweet (same goes with the mobo and ram - gift, yay)
yeah the asus p5e can use the Maximus Formula bios for sure, however it is updated to the current bios spec.
anyone want WD 320Gb (3-off in all) ? cheap make an offer, but been error-prone for me. desktop weights atm.
Cara! I gave you advanced warning about that and you still fell for it :sweat:
ben sent it via msn............didnt recognise the url for it
Weirdest shit - I have a MASSIVE craving for peanuts at the mo :)
andy are you pregnant? :)
:) i miss all the good shit
but meh, i bet it would have been funnier in japanese :sweat:
sorry, but no.
it doesnt get much better than crack whores, meth heads, single wheel peels, near collisions, and swearing that you can hear from a block away.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
