Any one here used Potenza G3's, RE-01, Toyo T1R, Toyo R1R?
Im in need of new tyres and thinking of one of those tyres. Also are the R1R a semi slick?
thanks Luke
I run nothing BUT T1R's.... they are, imho, the best tyre out there for street users. There are better track tyres, but the Toyos suit my style..
Diff tyres will suit diff drivers... I know the eagle f1 asymmetricals are rated higher than the toyos in some tests, and I may give them a try some day, but I've been more than happy with my toyo t1r's....
-D
cheers mate, Need a tyre which can take track work also, until i get 34 gtr wheels with semi slicks.
the t1r's will cope with whatever u can throw at them - in a street scenario
they do lose traction during high lateral G cornering (usually when you have 215's - not so pronounced when ur running 265's)
they are one of the best wet weather tyres out there... however I'm curious about the test wheels magazine ran recently where they score the f1 eagle asymmetrical rather highly (i think thats the one?)... either case, it was an interesting report and I think if you're gonna get new tyres, you're going to want to read it so u can select the tyres u want for the specific application...
if you want info about track tyres, im sorry but i dont know anything about that... but ive heard the toyo r888 semi's are very highly regarded
-D
thanks Luke
Chef is using the R1R's on his GTR. From memory, they're borderline semi's.
If they're used on his GTR, then they must be nothing short of awesome.
grr..after searching through the 31 forums..and to no avail...what price would i be looking at for a good condition 20det box? with clutch/flywheel etc. someone said 500 or so..just thought id see what some people say on here..
PM this guy http://www.skylinesaustralia.com/forums/R3...ts-t262240.html
he has one for sale and is online right now :)
..::edit::..
he is not in adelaide, but is helpful and will be able to give u a price
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
