Any one here used Potenza G3's, RE-01, Toyo T1R, Toyo R1R?
Im in need of new tyres and thinking of one of those tyres. Also are the R1R a semi slick?
thanks Luke
I run nothing BUT T1R's.... they are, imho, the best tyre out there for street users. There are better track tyres, but the Toyos suit my style..
Diff tyres will suit diff drivers... I know the eagle f1 asymmetricals are rated higher than the toyos in some tests, and I may give them a try some day, but I've been more than happy with my toyo t1r's....
-D
cheers mate, Need a tyre which can take track work also, until i get 34 gtr wheels with semi slicks.
the t1r's will cope with whatever u can throw at them - in a street scenario
they do lose traction during high lateral G cornering (usually when you have 215's - not so pronounced when ur running 265's)
they are one of the best wet weather tyres out there... however I'm curious about the test wheels magazine ran recently where they score the f1 eagle asymmetrical rather highly (i think thats the one?)... either case, it was an interesting report and I think if you're gonna get new tyres, you're going to want to read it so u can select the tyres u want for the specific application...
if you want info about track tyres, im sorry but i dont know anything about that... but ive heard the toyo r888 semi's are very highly regarded
-D
thanks Luke
Chef is using the R1R's on his GTR. From memory, they're borderline semi's.
If they're used on his GTR, then they must be nothing short of awesome.
grr..after searching through the 31 forums..and to no avail...what price would i be looking at for a good condition 20det box? with clutch/flywheel etc. someone said 500 or so..just thought id see what some people say on here..
PM this guy http://www.skylinesaustralia.com/forums/R3...ts-t262240.html
he has one for sale and is online right now :)
..::edit::..
he is not in adelaide, but is helpful and will be able to give u a price
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
