Any one here used Potenza G3's, RE-01, Toyo T1R, Toyo R1R?
Im in need of new tyres and thinking of one of those tyres. Also are the R1R a semi slick?
thanks Luke
My R34 came with 255/40/17 G3s on the rear and they were absolutely awesome in all conditions. Problem is due to the unusual size, when I went replace them was quoted over $400 each. Fail
im going the G3's on the silvia for the fronts next practice.
ill find out how they hold up compared to the bridgestones ive got now that after 2 track days, their already ready to be moved to the rear to be finished off haha.
You actually want to use a KKR turbo?!
Okay.
im using a kkr330 turbo on the drift car but the internals are all replaced with garret gt28 stuff.
pretty awsome turbo, comes on boost pretty hard all the way to redline!
Edited by Import S13
I went to look at a 34GT-T at Torque Motorsport on the weekend, ment to have done 64,000kms yet the interior was more warn then mine and i have done 109,000kms....
They wont give you any history either. Or let you drive it until you negotiate a deal, signing papers saying you will buy it subject to the test drive.
Why the hell does there have to be so many dodgy Skylines around. Gives me the shits.
Sounds all like Synergy Motorsport to me!!
Mate looked at a Supra, had to sign papers and put down a non-refundable deposit, etc after a test drive even though he wasn't keen on it at all after the test drive.
I'd steer away from them then. Sounds dodgy as. Reckon they've turned back the odometer?
you dont *have* to do jack. If you've driven it and dont like it, just walk away.... and if they point a firearm at you to make you sign it, the contract is void as per terms of duress
-D
Yeah I think there is something up. With KMS that low the interior should be immaculate, the wear on the steering wheel and gear knob was really bad and there were a few holes in the carpet under the drivers mat. Everything inside was more warn then mine.
The engine sounded healthy and looked clean but it could have been replaced. Cant drive it to test the gearbox which is a pain!
There was also a bit of the body kit burned/discoloured from the exhaust. My dad said it looks like a respray on it, and it only had one tyre guard which was a bit odd.
I tried to get some history but all they say is they get them from interstate and there is a privacy request....
rofl at privacy request on a used car.........I would've laughed my brains out all the way to the door.......and that would put me off any seller like that for good.
that's it just take your money else where! i buy my car when they let me test drive and if they seem a bit worried then i'll let them hold on to my license!
All imported cars look clean, especially the engine, after it's been blasted and cleaned in quarantine!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
