So in otherwords im pretty much farked and its gunna cost me a shitload. So no matter what im gunna have to get it cut out welded in new then complied then checked thru regency because what 10mm of metal was cut out!!!!!!!!!!!!!!!
Yeah all lights were working but not having driven the car let alone at night for 2 months as its been defect genarally makes it a little hard to tell, since its illegal to drive the car on the road day or nite.
Im sorry but 10mm is bulls##t. To defect on that which is gunna cost some1 whos not hooning around breaking the law, asalting ppl just enjoying motor vehicles is crap
did they go right for them? its stupid you can drill a hole for FMIC pipe but not 6x9? the fmic hole would affect the crumple zone more then 6x9.
i was within a day of cutting my rear deck to port the sub thru, damn it!!!! do i rethink the port or hide it really well under carpet on deck and block access from the boot to speaker deck ? REGENCY SUX end of rant.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
