Optima Yellowtop Deep cycle... I got one a couple of months ago. Not cheap but really good quality, sealed and with enough capacity to run yr subs at the drive in thru 3 movies...
-D
awesome, are they lead acid?
pete was telling me yesterday that u cant have lead acid batteries in the cabin/boot
.:edit:. just saw that u said its sealed
http://www.optimabatteries.com.au/Content/...D51R_082004.pdf
Thats the datasheet for the one I got, the D51. You most likely will have to have the japanese battery straps/terminal clamps replaced with the larger australian straps as the poles are thicker on aus standard batteries than the jap ones
Mine cost me over $300 but under $400 from a place in pooraka... got that and the two terminals installed at the same time the auto electrician removed and replaced the corroded fusible link, labour was just over $100 for that but if you're just getting the clamps replaced then it won't be much more than $50 i'd assume
-D
cheers ben, i dont have that much sound equipment to run. so im sure i could get away with one of the lower end ones and save a few $$
hows this, my dog has been playing fetch with a lemon LOL
he just keeps on bringing it back and making funny faces
Heh reubens barichello just owned the stupid channel 10 reporter..
he gets out his car, and the bloke comes over and sticks the mic in his face and says 'Ruebens, number 2 on the grid, it doesnt get much better than this does it?"
Barichello pauses and says "Well except number one...."
Classic.
-D
Edited by Dohmar
Suffering from too much sun headache from yesterday and F1 on ONE today, along with slow wireless net I got bored...
this is what could happen soon with the economy failures worldwide. a quicky edit but worth a laugh. , need to print it off to hand out to our friends in the next car show..lol Ford and Holden merger for a truly crappy tuna boat car with couches for seats
Edited by sapphiregraphics
I was going to hurry to get my car off defected and all the shit back on.. But I think I might leave it now.. Maybe put my exhaust back but that's about it. Looks like there will be some extreme reamage on the horizon!
the modified car scene is dying a slow death, iv re-concidered
buying another car, is it really worth it? where will i get to enjoy it?
im better off buying a go-kart, atleast good times will be had with me
and the little one (when its old enuf) without fear of defects/hate from the general public...
im gonna leave mine in the garage for the next few weeks and ride my pushbike to work
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
