Optima Yellowtop Deep cycle... I got one a couple of months ago. Not cheap but really good quality, sealed and with enough capacity to run yr subs at the drive in thru 3 movies...
-D
awesome, are they lead acid?
pete was telling me yesterday that u cant have lead acid batteries in the cabin/boot
.:edit:. just saw that u said its sealed
http://www.optimabatteries.com.au/Content/...D51R_082004.pdf
Thats the datasheet for the one I got, the D51. You most likely will have to have the japanese battery straps/terminal clamps replaced with the larger australian straps as the poles are thicker on aus standard batteries than the jap ones
Mine cost me over $300 but under $400 from a place in pooraka... got that and the two terminals installed at the same time the auto electrician removed and replaced the corroded fusible link, labour was just over $100 for that but if you're just getting the clamps replaced then it won't be much more than $50 i'd assume
-D
cheers ben, i dont have that much sound equipment to run. so im sure i could get away with one of the lower end ones and save a few $$
hows this, my dog has been playing fetch with a lemon LOL
he just keeps on bringing it back and making funny faces
Heh reubens barichello just owned the stupid channel 10 reporter..
he gets out his car, and the bloke comes over and sticks the mic in his face and says 'Ruebens, number 2 on the grid, it doesnt get much better than this does it?"
Barichello pauses and says "Well except number one...."
Classic.
-D
Edited by Dohmar
Suffering from too much sun headache from yesterday and F1 on ONE today, along with slow wireless net I got bored...
this is what could happen soon with the economy failures worldwide. a quicky edit but worth a laugh. , need to print it off to hand out to our friends in the next car show..lol Ford and Holden merger for a truly crappy tuna boat car with couches for seats
Edited by sapphiregraphics
I was going to hurry to get my car off defected and all the shit back on.. But I think I might leave it now.. Maybe put my exhaust back but that's about it. Looks like there will be some extreme reamage on the horizon!
the modified car scene is dying a slow death, iv re-concidered
buying another car, is it really worth it? where will i get to enjoy it?
im better off buying a go-kart, atleast good times will be had with me
and the little one (when its old enuf) without fear of defects/hate from the general public...
im gonna leave mine in the garage for the next few weeks and ride my pushbike to work
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
