news.com.au has to f**king go. this is my response to the topic http://www.news.com.au/adelaidenow/story/0...5006301,00.html
The article itself is benign however the poll has two loaded questions. loaded meaning any media turd can twist the results to his or her own devices.
This is what I wrote to them. I doubt they will have the balls to publish it, let alone act on it.
Lets see if they grow a pair of balls, or a conscience for that matter.
f**king scumbags.
-D
nicely said ben.........nicely said.
all i can say about the media in that article is go and get f'd ,
im fking sick of these immature little pricks who think cars are toys and try drift n shit on public roads
thank you for ruining it for the rest of us !
its a 32. :)
and it was posted on the last page. and in the track thread.
and i have to do this,
ladies and gentlemen,
the game.
that is all.
Edited by scandyflick
its a 32. :)
the game.
that is all.
oh yeah closer look at the back of it, its a 32...lol time for bed..lol
.... my mate is with internode, after his download limit, his speed is cut down, and DOESNT get charged for over use.
guess where ill be taking my custom soon.
When you sign up to an internet plan you agree to the terms and conditions. Simple as that - y0ou chose a plan/provider that charges for excess downloads.
i dont mind paying 200 bucks, fair nuff, but over $1000 for 1 month internet? c'mon, get real.
You physically CAN NOT download 20Gb of data and thought you were only using 6Gb. Unless you had P2P running 24/7 and shared out the 20Gb, of course - but in that case you shouldn't have been so stupid.
Either way, you did the data, regardless of everything else. If I was Optus, I am sorry to say, I would f$%k you hard.
No-one wants to accept the consequences for their own actions anymore .... a sad world when everything is someone else's fault.
Can you confirm that your usage was download data, and not upload? If it was indeed upload I have some sympathy for you, but if you actually downloaded 20Gb of data, then you MUST have know you were smashing your download quota of 5Gb.
lil help on assignment.
well its not really important but i wanted to add it. anyone know how many cars you can sell before you become a business? or where to find that info
Pretty sure Andrew knows :)
NOVA 91.9 this morning mentioned that they are shocked at another hoon driver crashing (red 32). However, they invited people from "the culture" (hoon) to ring up and say what is really going on. Didn't hear any callers however, anyone else hear?
I heard a little of what was said on Nova this morning. Didn't think there was too much constructive content and they has some drop kick loser try score points by telling listeners that he's clocked 250Km/h down South Rd in his VL Turbo.....
According to the article, serial offenders can actually have their cars seized and crushed.
Does anyone else think that is friggin ridiculous!!!!!!!
What if the car is an R34 GTR? that's some serious $$$ going in the crusher,
that's not even the point though, they can't effectively steal your car!!!!
That's absolutely disgusting, I had no idea we were living in a dictatorship.
What if the car is an R34 GTR? that's some serious $$ going in the crusher,
I heard the cars of value would be sold off to compensate victims of crime, and low value cars (shitboxes) would be crushed.
The way I see it, some decent cars are being written off by hoons anyway. The end result is almost the same, but the driver/passenger gets hurt/killed in a crash.
Edited by RubyRS4
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
