any one gonna listen to the ''street racing special'' on nova tomorrow?
starts at 11, they wanna hear the other side of the story apparently...
$50 bucks says some lizbeeeefan calls up bragging bout doing burnouts in his vl bro.
:ermm:
i hope a real enthusiast calls up to set the story strait, someone who can get our point heard
not mentioning any pete names.
It passed through the high court, we are getting it.
Tax commissioner Michael D'Ascenzo said 7.4 million people who had already lodged 2007-08 tax returns would begin receiving their bonus payments from next week.
:ermm:
do people out south all drive 800cc 3 cylinders diahatsus and not do anything illegal or "hoon"-like while driving?
I'll believe it when I see it. :ermm:
BTW where can I get RB25DET turbo gaskets (turbo-manifold and turbo-dump) tomorrow?
ATS have not been answering their phone all day ... grrr!
Edited by RubyRS4
Ryan got mine from nissan ruby...
im pretty sure he had to order it though?!
got a leak? be careful of the studs!
I'm sure ATS would have them in stock, but they haven't answered their phone all day (made over a dozen calls all day).
Not sure if I have a leak, but I want to rule it out. I don't believe there is a leak ... but, what can ya do. Guy heard the turbo spool up and complained of a failing turbo. I believe its only induction noise (very faint whistle), but worse case is loose nuts or leaking gasket. Either way, I want to rule it out. I've had a failed turbo before and I know what one sounds like.
Can anyone tell me if ATS is normally open on Saturdays?
Edited by RubyRS4
rubes pubes,
if your gasket was leaking, it would sound kinda like a screamer, whistling? id say induction..
imho, its not worth the risk of snapping turbo studs, for something thats completely fine.
he prob just tryin to make shit sound broken to screw you down on price.
IOm with craig 33 on this one roo.
Hes probably just trying to find ways to get more off the price. Ended up being a tryekicker/joyrider. DICKHEAD
With the engine idling you should be able to hear it leaking around the area with the old garden hose to your ear trick id say
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
