Yeah I've got that long arse threaded nut thing that I'm guessing is to add/release tension on the pulley but when I undo it it starts to come out of its thing and the pulley just stays where it is (as opposed to moving closer to the engine so I can get the belt off)
You also need to loosen the pulley nut itself, as that locks it into place. :(
^ yeah I missed that little bastard nut hiding under there :(
Would've been a lot easier if it was in a 32 or something, I can't actually fit my fking hand between the pulleys and the radiator, had to maneuver around them ;)
Got it on though :P
Edited by AndrewJZX100
Working my ass off today ...
Thanks to Damo (tryandcatchme) for loan of the ladder and lending a hand to get the purlins into place ... 5 more to go, but can't be arsed doing any more today.
Now you can see the shear size of the house extension. 102m2 ;)
Reckon jumping off the roof into the pool would be immature? :P
My back yard is an absolute mess now ...
Roof sheets go on this week right after I fit the remaining purlins.
Then I fit some tension bracing, before starting to fit the floor beams and floor joists.
Time for beer ... :(
be my guest, I want video footage though :(
I've hit the ground hard from dirt bike stacks ... this'll be an easy walk in the park having water to land on.
Better not let Tracy catch me tho ;)
Edited by RubyRS4
there's a skyline drive near the old spot hotel up north, much closer :( street sign has been stolen so much i think they welded it to the pole now.
So your telling us Dan that we now gotta take the whole pole instead of just the street sign...
got teh rolla started today with the new carby, and fix0rd fuel tank.... think i pinched one of the fuel feeds out of the fuel tank tho, not much fuel is coming thru.
bah, didnt want to have to take the tank out again
I've hit the ground hard from moto-cross stacks ... this'll be an easy walk in the park.
Better not let Tracy catch me tho :(
I'll put my hand up to film it then.... we'll even get the paramedics there on standby shall we.... ;)
I'll put my hand up to film it then.... we'll even get the paramedics there on standby shall we.... :(
"The following stunt is about to be performed by a professional 'jackass'.
Please do not attempt to recreate the following stunt ... or you'll be a dumb f**k too!" :P
Perhaps you might even find the video later on You Tube under "idiot misses pool" ;)
w00t w00t
sounds the goods chad, nice and clean
how much do you reckon he'd charge for some paint touchups / getting rid of a bit of rust out of one door?
Not to sure mate. I can give you his number if you want, work shop is called C.W Crash. Only prob is he is all the way out at Salisbury :blink: long way for us dirty southerners. Another good place down south is Daniel Stone Painting at Hackam, he did my 34 rims.
Not sure whats its gonna cost me, maybe nothing if my sister tells him to :D
Edited by DSTROY
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
