I'm not that old, I make my own sauce, it's the best :unsure:
same, me and the missus make the sauce together with my olds each year. cant beat it, nothing in the shops can match it :unsure:
na thats no campelltown high that's a mix the old thorndon high with campbelltown
i remember campbelltown high when i was a youngster, old high school on playford Rd in Newton. All gone now, all real-estate
i used to live just round the corner from it. Now i live a little further away, basically still around that corner though, haha
went to the atm to take out some money and it seems i have recieved k rudds package! i only got $500 and this concerns me the most! it doesn't matter if i got $500 when i'm suppose to get $900 but it could mean someone withdrew $400 from my account which worries me the most! so now i have to wait till tuiesday to go to the bank and see what's going on
does anyone know much about gtr power fc is a gtst? i know madaz has got the same kinda set up but was wondering id anyones knows how i can get vct on the gtr power coz i find that i dont hit full boost till 4k with the new turbo (it maybe just the turbo but i dont think it is) any ideas? and know i cant find any other forums talking about it i hate the search lol
If you have Online Banking check your transaction history ASAP, or go to an ATM and get a mini transaction history for 10c or so.
bloody hell dude when you expecting full boost by then.....2000rpm?????
its the turbo, expect more lag when upgrading to a bigger turbo
what size exhausting housing u got in it???
why didnt u get the gtst power fc in the first place???
ahha settle down, i know its not gunna make it but 2k i ment more around 3.5k after having friends with the same kinda set up, stock housing just bored right out, and i brought the car with a gtr power fc i didnt put it in (not that stupid)
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
