thinking about changing to one of these
wait till you throw a balance shaft on the 4g63, mine did off idle , a very common problem, destroyed the block in seconds. and the all wheel drive fuel economy sucks.
mitsu dependability :cool:
turbo failure a few months later, and a few clutches, gearboxes, and transfer cases later.. good thing it was only a daily not a racer, or it would have never made it to the race track...daily driver, hell it was broken down more then it worked..lol
and that was on a basically stock tune evo/vr4 drive train, not a highly tuned monster.
plus R34 prices have fallen into the toilet for resale ?
go for the Lada..lol they come with duct tape and bailing wire to make them last forever..lol
I drove Munro's Evo 8 when it was brand spanking new and it really didn't inspire me .... and looked like a chick's car .... yawn
At the end of the day it is STILL a lancer
so i went to lonsdale to get my r32 inspected (vic -> sa) and of all the things i could possibly get picked up for...window tinting...
'too dark on the rear quarters and the whole rear window'.....silly stuff, guess im back to peeling...
mitsu dependability :(
I knew someone would piss on my parade :(
parade pissing is awesome.
a 19mm nut on my front left strut pissed on mine, last person to work on the suspension partially rounded it. cant fit a 19mm anything onto it. pu.
Did they let you drive it away from there? When I changed over rego at Regency on my old MX6 in 2002 they gave me a razor blade and told me to get the tint off on the spot, else get a tow.
Sounds like a light angle grind on each side then a shifter spanner or locking pliers Dave. Works a treat!
+1 have done this a few times,
also a thin file on a rounded phillips head makes for a good ghetto once off flat head fitting
anyone know when/how carsales.com updates? or anyother sites i should check out
im pretty sure tradingpost.com is every thursday but i dont know about the other sites.
i like to keep my eyes peeled for any 240z dato's for sale amunst a few other oldschools. 14k is the best ive seen for a clean 240 so far.
cops wont hate on it and i might even be able to park at shopping malls with it.
Edited by Inline 6
lol sounds like my issues dave, sinergy put my tires on and obviously used the wrong size socket on my expensive blue alloy lug nuts. had two rounded out in a big way, they went thru the trouble of filing them off after they got them off to remove the burr they left . only issue was it shows bad on blue nuts when the rest of it is shiny alloy.... trained monkeys , a socket must fit tight on the lugs or the rattle gun kills them when you hit the trigger, its not rocket science ????
Oh damo,, its always better to piss(hear about issues) before you shit(buy a piece of shit)
you could always buy a forden executurd...lol
build a RB30DET GTR driveline, VE holden.. ex cop car...lol talk about stealth
AFAIK those sites are live, so once u submit an ad it is up for the length of time that u pay for (much like ebay)
Or enclose the bottom of the VE, put a few fins on, and turn it into the boat that it is. RWKW? I think not. How many killerwasps do you have at the prop man?
For all you Galaxy, Star-loving people out there...
Earth is tiny compared to these other planets:
http://digg.com/d1ofQT
i didnt know jj.am had educational stuff? i thought it was all just naked chicks and racist gifs.
you know what that all means though? we all gotta start compensating for size of our planet.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
