Just went for a cruise to the shops.
Looked at weather on the net first. No rain.
as soon as i fin washing the car it comes down. always does. always.
Also. A high number of ambos with lights on tonight. Seems the usual tailgaters cant do it in the wet,
Because of you Chad (yes, I'm blaming you :D ), I am now $10,000 poorer.
I pick it up tomorrow night. So it looks like I'm back into another Skyline :bunny:
Cant wait!
Nice one Kye :) Looks like a winner for sure :bunny:
-D
That 33 front on a 32 is disgusting!
Agreed.
And while rain always does come at the worst time, it actually worked in my favour and washed off a big ass bird shit on my roof... 5 seconds of flannel work and shes GONE
-D
wootage
Acquired a set of GTR sway bars tonight :D
RB25 BOV will be on it's way early next week :bunny:
Mate has a bleed valve I can have for free :bunny:
Recently got around to fitting black mesh to the openings in the front bar and grille so it looks neater :)
"the list" of shit to do to the car is slowly being ticked off, and so far a lot of the shit has cost me less than what I was expecting :D
Edited by AndrewJZX100
some days i wish i never stepped in a kitchen
this morning one of my f***n fryers decided to catch alight so we had to close the whole kitchen down and call the CFS, then tonight, i went and burnt myself aswell as being extrmeley paranoid about the other fryer and the ovens catching alight, arrghhh! not fun!!
lol nah nothing like that at all steve - i wasnt even near the fryers,not even using them, was chopping something tunred around and the thing was on fire!!!!
Wwas very scary thats for sure.........took a good couple of hourse before my heart rate went back to normal and i stoppped shaking.......
first instinct was i grabbed the fire blanket that was right next to me and chucked it over, aswell as turning off the fryers, and the stove tops, ovens etc
ive never had it before and i dont want it to happen again, im just glad i wasnt in the middle of service when it happened.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
