nice cara should be a reliable ride there not we all have dailies who are we going to spot
lol not that you guys are gonna spot me when im here at tailem bend anyway :P
but dont worry the 34 will be around....just not as much gonna get her into show car material :wub:
pffft
ill be supercharging before i turbocharge anyday honey hehehehe :P
should've supercharged the rolla! it'll get your blood pumping more than most cars with a 15 pound pulley
Edited by nos man
what-a-f*kin-head-f*kk!!!!
purchased a new ESET anti virus licence over the net tonight,
couldnt enter my free web based email address to recieve the relevent codes.
so entered my 3 mobile address that i use for work on the company phone, little did i know
the boss changed our e-mail addreses to our private server :P
ffs
soooo now im gonna have a big deal on my hands to get these codes now ay?
how can you tell if a lsd is still in good nik just by looking at it?
generally you cant tell if the lsd is any good until a good 30 minutes after you've bombed it... cant tell by just looking at it, one tab looks the same as any other :)
-D
When setting them up properly you use a torque wrench to test the torqueand you use shims to adjust the torque so you can use the same technique but you will have to make up something to attach the torque wrench to the hub.
EDIT!! Just actually read your post....you can't tell by looking at it.
Edited by D_Stirls
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
