you by the sounds of it.........
what is everyone up to today anyways?
im doing more research on parts prices for the R34 at the moment............
im regretting saying i could work tonight cause now i cant pick my engine up :blush:
epic fail
looking up stuff that im gonna need for my build for the supercharging project.
i dont need to worry about the engine side of things cause i have Chris Milton Engineering Developments sorting that side out for me, its just everything else i need to sort out.
Good turnout at Enfield RSL's dawn service in spite of the rain and it being a Sat... couple hundred there easily :blush:
-D
Was a good turnout at brighton dawn service
as was there in town at the march
and need i say, it BELTED down with rain (just as our unit was about to turn from north terrace onto king william road.......and it rained all the way through to the end just by the memorial hospital
    • You're already well into "gearbox is a consumable" territory there. A billet plate will either make it (effectively) 1% stronbger or make it last one more pass. At some point you'll probably tear 3rd gear into small chunks and regret all the life decisions that came before it.
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
