i go into fone shops and they ppl there cant tell me which phone does what..
im like advantages of the iphone over the BB storm.. umm... its an iphone..
like WTF!
edit: nah i cant craig.
Edited by rad32
anyoneknow what might cause laginess in first gear? and dont say cause my car is non turbo:P
try a new service provider oh wait your not talking internetz
well when one of you buggers do your homework on the BB Storm, let me know cause I'm fed up with my HTC Dual Touch.
what you have to use 2 fingers
i went to replace my cluster surround with one that i bought from another member on here. when i got the donor one in, the headlight switch only powered one light.
when i took it out to test the origional switch again i damn near tore off a fingernail on one of those mo fo electrical plugs with the press release...
needless to say i left the car in the shed looking like someone was trying to steal it with no cluster surround or steering shroud lol
hey pete,
read some reviews..
lacks WIFI.
only avail at vodafone. (no problem for me)(cant buy outright)
but on there plans u get unlimited BB emial and web.
seems like a very good unit..
sure touch screen seems only worry..
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
