anyone in the market for some new gutters after this rain? just had mine replaced by a company that did a UTTER crap job at my GUTTERS. tryed to charge me $700 extra on top of the quote because there guy cant use a tape mesure, didnt replace about 4mtrs of guttering thats in the contract, leaks like a seive, wont return calls (been 2 weeks and im still waiting for a reply) and the water that should be going down the drain is now comming threw my ceiling! :(
hey pete,
read some reviews..
lacks WIFI.
only avail at vodafone. (no problem for me)(cant buy outright)
but on there plans u get unlimited BB emial and web.
seems like a very good unit..
sure touch screen seems only worry..
Im going to get the Samsung Omnia when i upgrade in a couple of months, unless something better appears. Buying a phone outright is pointless if your on a plan, why pay $7-900 for a phone when you can pay $10 a month for 24 months?
Try the N97, looks feature rich, touch screen if you like that wanky shit and build quality only Nokia can match
nokia?
build quality?
GUFFAW! Worst phones I ever had were nokias...
switch to sony ericsson 5 years ago with the t68i then the k750i and now the k850i.... awesome rock solid phones >:( and they dont crash like nokias
-D
Blerrgh! Sony Ericsson? Puhlease! While I will agree with you first gen Nokia firmware leaves something to be desired, by the time the second firmware is released problems are sorted and they often add new features well after the shelf life of the phone
thats not good to hear Rob
hope they can get that sorted out soon
as water coming through ceiling isnt good for the house lol
I was happy to see my house extension still standing after the weekend of wind and rain :( Means I'm doing something right :(
i went to replace my cluster surround with one that i bought from another member on here. when i got the donor one in, the headlight switch only powered one light.
i replaced my switch thinking that was the prob and still had the 1 head light issue, ended up being some lil white box on the steering wheel column that wasnt getting power to both lights.
o and all phones suck :( you wanna go on the net? get a laptop. and what spaz's buy ringtones when you can just put mp3 files on them for free stop encouraging those annoying adverts that interupt my nba playoffs.
Edited by Inline 6
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
