My PC doesn't run CSS :woot:
It's so old.
I think we got one the other way around...
Wont play Medal of Honor Airborne (amongst other things)........ At first I couldn't even get it to install, googled it, found it was something to do with some physx drivers. Got around that, installed it but when you try to play, it comes up with a missing .dll. I googled that too and it seems it doesn't like some video cards, the computer has a GeForce 9600GT in it...... oh and Vista :)
I'm guessing u tried running it in computability mode
yeah tried both run as administrator and in compatibility mode for XP.
weird thing is though is if I google the name of the missing dll on it's own, heaps of the matches are from torrent sites :)
At which point I close internet explorer and chuck it in the too hard basket lol.
Edited by 93GTST
don't worry i already thought of that my reply is :) my passenger snapped it
besides i wasn't on the phone i was using a camera hey, hey, yeah technicality
but yeah don't want to be lying to police about not being on phone when camera phone is classed the same a big :woot: what to do he was very annoying and a bit dangerous too
The xinput dlls are for the Microsoft common controller library and are used for things like the Xbox 360 common controller.
>>DX Webinstaller<<
also have a read here there seems to be a lot of games that .dll is causing grief for
yeah i agree Ben and whilst i hate dobbing on people he really was a menace
maybe he wont stop that behavior until the public take 5 mins out of there time to file a report so police can officially caution him and then he will stop it just in time to not have a catastrophic accident
one of my mates mums is an officer maybe i should speak with her off the records
thats a good idea steve....speak to her off the records and see what advice she gives to you
adrian...mate i will be at Bp tonight a bit later on.....so come and get them as i most likely wont be home all weekend....so tonight sounds good mate
Edited by Krishy
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
