is that all pete? you didnt spend much time out my way eh?
sweet
south isnt that bad - what suburb?
christie downs or some shit. shouldnt be any worse than craigmore. :P
also, man that chick in your avatar makes me crack a phat
yup, same, thats why i put it there, you know, sharings caring.
i live in port noarlunga which is pretty much down the road from christies beach and downs.
some parts isnt amazing but like you said, cant be worse then craigmore :happy:
where abouts in chritie downs you living?
Put this over the airbag sticker
I don't know whether to tisk dissaprovingly or piss my self laughing
Theres heaps more.. some rather lame.. such as the V8 one at the bottom
Edited by Stagstock
hmmm steve is closest lol
i will provide the case, but have nfi what the best parts are, computer stupid you see.
Can do something for u if u want. I'll be getting a new i7 based system with 6 gigs of low latency ram, 15k rpm SAS drive, nice motherboard, entry level vidcard, 2 terrabyte server drives... etc
around $1.5k worth for something like that. depends what u want the system for and how much u wanna spend. its easy stuff tho
-D
i spent a few seconds trying to figure out why this sounded familar.
then i remembered the wheels, and sizes are exactly the same as ben was gonna run as track wheels.
another coincidence? gonna get some fat viennas as show wheels too?
:P
shutup dave you smartarse :happy:, i was looking into other options anyway. wasnt left with a lot considering the rear guards have been massacred that bad.
(editing AFTER my computer shat itself)
1. hunt for second hand wheels in low offsets
- pros: sick wheels, jdm appeal, extremely stupid width and offsets
- cons: chance of finding something in as low an offset as i need, buckleys to none, and i would need to run spacers
2. buy new jap wheels
- pros: wheels in good width, offset and in my stud pattern
- cons: limited range, price is absolutely rediculous, need spacers more than likely
3. get ROH modulars made
- pros: wheels will fit without spacers, will be exactly what i want
- cons: takes a while for them to be made (2 odd months lead time)
considering it was 5k for meisters, or around the 2k mark for 1pr front and 2pr rears, i think i know what wins while trying to build on a semi-budget
Edited by Matty 31
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
