Put this over the airbag sticker
I don't know whether to tisk dissaprovingly or piss my self laughing
Theres heaps more.. some rather lame.. such as the V8 one at the bottom
^^^ I may or may not have this sticker on my R34 just for shits and giggles :D
anyone done the thermo fans and removed the clutch fan? looking into it. as i think my clutch fan is dying.
any points in the right direction would be chilled.
Yep I did it. Fairly big job, as the non-oem EL style dual thermo fans I bought did not actually fit between the chassis rails, but I made it all fit with an angle grinder and some cable ties. It will not fall out in a hurry, let me guarantee you!
But yeah, once I got it all fitted up it is awesome. When they come on it is so noisy it sounds like the world is ending, but even on a hot day my Cooling Pro radiator stays around the 90 degree mark.
I would highly recommend you buying a Pivot fan controller to run them though - as running them full time is not recommended (and noisy).
TBH I don't know exactly how much benefit they really give over the stock clutch fan - I actually think it is not worth the upgrade unless your existing fan is dying (like you say), and you want to have a play with your car.
cheers to those who offered to help me build a pc.
steve quickly whipped something up, in my budget, and sounds pretty good for what i need it for!
:D
EOI: 2 y/o pos toshiba satellite laptop, N/A (pretty slow) only 1.6ltr (ghz) and only scored 1 pussy (1 gig ram)
f**k me.
What a weekend.
Friday night: met a whole bunch of hot emo's at that Syke place next to Electric light. That was some sort of win. Then went for skids in a 4age KE70 with cut springs, locked dif and a crazy fuel pump/surge tank/swirl pot setup.
Saturday night: Went to the CD launch of Trancefusion at Live on Light Square. F*cking smashed it until 5am... then hit Earth til 6am, then Club 58 til 7am. Got home at 8am. Such a dirty night.
So much amounts of win.
And why the f**k do MC's feel the need to talk/attempt to rap/sing over DJ's sets? I went to Mansions at 1am to see Black Wax play, but they had a top bloke MC just rapping over the whole set, screaming shit like "Black Wax is in the house!" Well... no f**king shit.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
