Guest CleanAndSimple
personally i'd bite the bullet and re-image the laptop and start from scratch
+1... I Find once something like that appears, its never the same until its re-imaged.
Boot in safe-mode backup files, and format
Edited by CleanAndSimple
i need some help lol
laurens lap top did something weird a few weeks ago. we turned it off one night then on the next day and all her programs on her desktop and her background had gone.
all her files and dtuff are still there and so are the programs just hidden in a file deep in windows lol
any ways she went to upload to music on to her ipod and had to sort of re install itunes, itunes was still on her desktop and in program files so we were hoping it would still have all her music on the library etc but apparently not
so our problem is how can we get back the old itunes and her music library because atm she only has the music that is on her ipod and she doesnt want to sync it to the new itunes cos it will delete it
sorry for the novel
any help would be great
Thanx guys
several scenarios ; the active desktop on background has been turned on and thats why the icons went missing
or explorer crashed/isnt functioning properly
if you want to find the files, do a windows search for *.mp3 and *.aac and *.mp4 files and copy them all to an external source (hdd or dvd)
or it could be a simple case of the profile becoming corrupted. check under c:\documents and settings for multiple instances of laurens login profile, if shes kept default directories most of the ipod music will be under her documents folder or tucked away somewhere in c:\program files
-D
F**king Sprints gave me the wrong water pump so now i cant finish the 100k service and cant find the recipt :P
might have to miss this track day :ninja:
In other news my tyres arrived today :ninja: KU36 baby
sorry for the novel
Thanx guys
Have you tried system restore?
Your problem is Luke that I bet they don't make an R34 pump - heaps of people told me that R33 pumps are exactly the same, but Nissan confirmed that they definitely are not. They also aid anything but oem pumps will root your engine. But I suppose Nissan say that about all non-oem parts.
Same as clutch fans - everyone tells you that R33 and R34 are the same, but I found out the hard way they are slightly different bolt pattern.
cause apprently they are exactly the same, which now i found out they arnt. Hope they can swap it over no probs. Now i wish i brought genuine.
You got an RB30 one didn't you? The one they say will fit, only to find a bolt hole doesn't line up?
Common thing for idiots sitting behind a desk to do. As Andrew said, with shit like that, always go direct to Nissan. I'm able to get good pricing from Lakeside, want me to see how much one is for you and availability?
I'm going to be getting a AM dump front pipe as soon as Andrew has made one for me, do you guys think it needs heat wrap... keeping in mind I run stock boost?
im getting one too. :ninja:
id heat wrap it, but thats just cause im lazy and cant be arsed with heat shields.
also, when the f**k did i hit 3000 posts? :P
and i have a trader rating... i gotta start paying attention.
Edited by scandyflick
Good choice Talbo, Andrew makes AWESOME systems, you won't be disappointed. I'm in two minds about heat wrapping but I think on a standard street car, it's pretty pointless
Thanks Luke, confirmed what I was thinking :P
I'm getting one his hi flow cats too :ninja:
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
