Guest CleanAndSimple
personally i'd bite the bullet and re-image the laptop and start from scratch
+1... I Find once something like that appears, its never the same until its re-imaged.
Boot in safe-mode backup files, and format
Edited by CleanAndSimple
i need some help lol
laurens lap top did something weird a few weeks ago. we turned it off one night then on the next day and all her programs on her desktop and her background had gone.
all her files and dtuff are still there and so are the programs just hidden in a file deep in windows lol
any ways she went to upload to music on to her ipod and had to sort of re install itunes, itunes was still on her desktop and in program files so we were hoping it would still have all her music on the library etc but apparently not
so our problem is how can we get back the old itunes and her music library because atm she only has the music that is on her ipod and she doesnt want to sync it to the new itunes cos it will delete it
sorry for the novel
any help would be great
Thanx guys
several scenarios ; the active desktop on background has been turned on and thats why the icons went missing
or explorer crashed/isnt functioning properly
if you want to find the files, do a windows search for *.mp3 and *.aac and *.mp4 files and copy them all to an external source (hdd or dvd)
or it could be a simple case of the profile becoming corrupted. check under c:\documents and settings for multiple instances of laurens login profile, if shes kept default directories most of the ipod music will be under her documents folder or tucked away somewhere in c:\program files
-D
F**king Sprints gave me the wrong water pump so now i cant finish the 100k service and cant find the recipt :P
might have to miss this track day :ninja:
In other news my tyres arrived today :ninja: KU36 baby
sorry for the novel
Thanx guys
Have you tried system restore?
Your problem is Luke that I bet they don't make an R34 pump - heaps of people told me that R33 pumps are exactly the same, but Nissan confirmed that they definitely are not. They also aid anything but oem pumps will root your engine. But I suppose Nissan say that about all non-oem parts.
Same as clutch fans - everyone tells you that R33 and R34 are the same, but I found out the hard way they are slightly different bolt pattern.
cause apprently they are exactly the same, which now i found out they arnt. Hope they can swap it over no probs. Now i wish i brought genuine.
You got an RB30 one didn't you? The one they say will fit, only to find a bolt hole doesn't line up?
Common thing for idiots sitting behind a desk to do. As Andrew said, with shit like that, always go direct to Nissan. I'm able to get good pricing from Lakeside, want me to see how much one is for you and availability?
I'm going to be getting a AM dump front pipe as soon as Andrew has made one for me, do you guys think it needs heat wrap... keeping in mind I run stock boost?
im getting one too. :ninja:
id heat wrap it, but thats just cause im lazy and cant be arsed with heat shields.
also, when the f**k did i hit 3000 posts? :P
and i have a trader rating... i gotta start paying attention.
Edited by scandyflick
Good choice Talbo, Andrew makes AWESOME systems, you won't be disappointed. I'm in two minds about heat wrapping but I think on a standard street car, it's pretty pointless
Thanks Luke, confirmed what I was thinking :P
I'm getting one his hi flow cats too :ninja:
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
