Guest CleanAndSimple
personally i'd bite the bullet and re-image the laptop and start from scratch
+1... I Find once something like that appears, its never the same until its re-imaged.
Boot in safe-mode backup files, and format
Edited by CleanAndSimple
i need some help lol
laurens lap top did something weird a few weeks ago. we turned it off one night then on the next day and all her programs on her desktop and her background had gone.
all her files and dtuff are still there and so are the programs just hidden in a file deep in windows lol
any ways she went to upload to music on to her ipod and had to sort of re install itunes, itunes was still on her desktop and in program files so we were hoping it would still have all her music on the library etc but apparently not
so our problem is how can we get back the old itunes and her music library because atm she only has the music that is on her ipod and she doesnt want to sync it to the new itunes cos it will delete it
sorry for the novel
any help would be great
Thanx guys
several scenarios ; the active desktop on background has been turned on and thats why the icons went missing
or explorer crashed/isnt functioning properly
if you want to find the files, do a windows search for *.mp3 and *.aac and *.mp4 files and copy them all to an external source (hdd or dvd)
or it could be a simple case of the profile becoming corrupted. check under c:\documents and settings for multiple instances of laurens login profile, if shes kept default directories most of the ipod music will be under her documents folder or tucked away somewhere in c:\program files
-D
F**king Sprints gave me the wrong water pump so now i cant finish the 100k service and cant find the recipt :P
might have to miss this track day :ninja:
In other news my tyres arrived today :ninja: KU36 baby
sorry for the novel
Thanx guys
Have you tried system restore?
Your problem is Luke that I bet they don't make an R34 pump - heaps of people told me that R33 pumps are exactly the same, but Nissan confirmed that they definitely are not. They also aid anything but oem pumps will root your engine. But I suppose Nissan say that about all non-oem parts.
Same as clutch fans - everyone tells you that R33 and R34 are the same, but I found out the hard way they are slightly different bolt pattern.
cause apprently they are exactly the same, which now i found out they arnt. Hope they can swap it over no probs. Now i wish i brought genuine.
You got an RB30 one didn't you? The one they say will fit, only to find a bolt hole doesn't line up?
Common thing for idiots sitting behind a desk to do. As Andrew said, with shit like that, always go direct to Nissan. I'm able to get good pricing from Lakeside, want me to see how much one is for you and availability?
I'm going to be getting a AM dump front pipe as soon as Andrew has made one for me, do you guys think it needs heat wrap... keeping in mind I run stock boost?
im getting one too. :ninja:
id heat wrap it, but thats just cause im lazy and cant be arsed with heat shields.
also, when the f**k did i hit 3000 posts? :P
and i have a trader rating... i gotta start paying attention.
Edited by scandyflick
Good choice Talbo, Andrew makes AWESOME systems, you won't be disappointed. I'm in two minds about heat wrapping but I think on a standard street car, it's pretty pointless
Thanks Luke, confirmed what I was thinking :P
I'm getting one his hi flow cats too :ninja:
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
