Dave if you need a hand putting the turbo back on give me a yell and I will come help too. If you can give me a day or 2 notice I can book my work around it.
FYI those water lines are an absolute bitch to get back on - the inside one particularly. Fun, fun, fun.
Mmmmmmmmmmm titanium .... I bet the retail on that bad boy is well the wrong side of $5k
cheers dude, shall let you know. im fairly sure the work shall be getting done on tuesday arvo.
yeah, water lines were the biggest pains in my ass... gonna get dad to see if he can find some suitable banjos, an fittings, and braided lines at work to replace them.
gah! forgot this was coming.
1337, scandyflick invaded your box. lul.
Edited by scandyflick
Just bought a fighter fish for my desk at work. Good times. His name is Bruce.
you can keep your lump of cast iron. :D
yeah, its been uh... interesting. ha. yeah, could use a bit of help putting it all back together. i shall provide beer for afterwards.
(and let you drive it of course)
thats why i come too he can drink and i can drive :(
hey heslo just thought u should know thats a pretty sexy GTR u got there, haha
need to catch up for that turbo pipe or somehow get it to Adrian if he still needs it if not no rush one day
Hello fellow Skyline owners. Need a bit of advice if possible.
Have found an r33 im looking into purchasing and am having an inspection done on monday. Just went through the ezy reg website to check the car was clear of finance and not written off etc. The person selling it says there is 106 k's on the odometer and when i got the reply back through ezy reg, it showed an odometer result of 186k's. Would ezy reg's reading be more accurate the guy selling the car? Should i go through with the inspection or just pass this one up and wait for the next?
Thanks in advance guys, really appreciate your help!!
:D
how did you check thorugh the ezy reg website did you have a vin number or somthing
Yeah i asked the seller for the,
plate number
engine number
and vin
Ezy reg charged $9 for the finance fee
and $15 for the damage write off check
:D
have it thoroughly checked out. afr's, compression, leak down, and all the obvious stuff like previous crash damage, basically have whoever's doing it go over it with a fine tooth comb, if its healthy and drives right, the mileage shouldnt really matter, but if it doesnt feel right to you, walk.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
